When I make an HTTP upload, the progress bar shows 100%, then "Transfer Completed", but the files do not appear.
The folder I'm uploading to has 755 permissions. 777 didn't work, either.
My applet code looks like this:
var _info = navigator.userAgent;
var _ns = false;
var _ns6 = false;
var _ie = (_info.indexOf("MSIE") > 0 && _info.indexOf("Win") > 0 && _info.indexOf("Windows 3.1") < 0);
if (_info.indexOf("Opera") > 0) _ie = false;
var _ns = (navigator.appName.indexOf("Netscape") >= 0 && ((_info.indexOf("Win") > 0 && _info.indexOf("Win16") < 0) || (_info.indexOf("Sun") > 0) || (_info.indexOf("Linux") > 0) || (_info.indexOf("AIX") > 0) || (_info.indexOf("OS/2") > 0) || (_info.indexOf("IRIX") > 0)));
var _ns6 = ((_ns == true) && (_info.indexOf("Mozilla/5") >= 0));
if (_ie == true) {
document.writeln('<OBJECT classid="clsid:8AD9C840-044E-11D1-B3E9-00805F499D93" WIDTH="768" HEIGHT="320" NAME="fileupload" codebase="http://java.sun.com/update/1.4.2/jinstall-1_4-windows-i586.cab#Version=1,4,0,0">');
else if (_ns == true && _ns6 == false) {
// BEGIN: Update parameters below for NETSCAPE 3.x and 4.x support.
document.write('<EMBED ');
document.write('type="application/x-java-applet;version=1.4" ');
document.write('CODE="jfileupload.upload.client.MApplet.class" ');
document.write('JAVA_CODEBASE="./" ');
document.write('ARCHIVE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar,lib/explorerui.jar" ');
document.write('NAME="fileupload" ');
document.write('WIDTH="768" ');
document.write('HEIGHT="320" ');
document.write('url="http://myserver.com/subdir/process.php" ');
document.write('paramfile="uploadfile" ');
document.write('param1="todo" ');
document.write('value1="upload" ');
document.write('param2="errorheader" ');
document.write('value2="custommessage" ');
document.write('param3="relativefilename" ');
document.write('value3="true" ');
document.write('folderdepth="-1" ');
document.write('encoding="ISO-8859-1" ');
document.write('transferui="jfileupload.transfer.client.explorer.ExplorerTransferUI" ');
document.write('resources="i18n_bar" ');
document.write('transferuiresources="i18n_pane" ');
document.write('mode="http" ');
document.write('scriptable=true ');
document.write('regfile="jfile_license.oxw" ');
document.write('transferuiparam1="regfile" ');
document.write('transferuivalue1="jexplorer_license.oxw" ');
document.writeln('pluginspage="http://java.sun.com/products/plugin/index.html#download"><NOEMBED>');
// END
else {
document.writeln('<APPLET CODE="jfileupload.upload.client.MApplet.class" JAVA_CODEBASE="./" ARCHIVE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar,lib/explorerui.jar" WIDTH="768" HEIGHT="320" NAME="fileupload">');
// BEGIN: Update parameters below for INTERNET EXPLORER, FIREFOX, SAFARI, OPERA, MOZILLA, NETSCAPE 6+ support.
document.writeln('<PARAM NAME=ARCHIVE VALUE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar,lib/explorerui.jar">');
document.writeln('<PARAM NAME="url" VALUE="myserver.com/subdir/process.php">');
document.writeln('<PARAM NAME="param2" VALUE="errorheader">');
document.writeln('<PARAM NAME="value2" VALUE="custommessage">');
document.writeln('<PARAM NAME="param3" VALUE="relativefilename">');
document.writeln('<PARAM NAME="folderdepth" VALUE="-1">');
document.writeln('<PARAM NAME="encoding" VALUE="ISO-8859-1">');
document.writeln('<PARAM NAME="transferui" VALUE="jfileupload.transfer.client.explorer.ExplorerTransferUI">');
document.writeln('<PARAM NAME="resources" VALUE="i18n_bar">');
document.writeln('<PARAM NAME="transferuiresources" VALUE="i18n_pane">');
document.writeln('<PARAM NAME="regfile" VALUE="jfile_license.oxw">');
document.writeln('<PARAM NAME="transferuiparam1" VALUE="regfile">');
document.writeln('<PARAM NAME="transferuivalue1" VALUE="jexplorer_license.oxw">');
// END
if (_ie == true) {
document.writeln('</OBJECT>');
document.writeln('</NOEMBED></EMBED>');
else {
document.writeln('</APPLET>');
Any ideas?
~Jorge
