Someone knows how to install JDiskExplorer on on SUN Web Portal.
JDiskExplorer on SUN Web PortalRe: JDiskExplorer on SUN Web PortalYou can install it as it was any other web server.
JDiskExplorer is a JFileUpload add-on. You need JFileUpload first. 1 - Download JFileUpload http://www.jfileupload.com/products/jfi ... index.html 2 - Download JDiskExplorer http://www.jfileupload.com/products/jdi ... index.html Then are you planning FTP or HTTP for transfer protocol ? Re: JDiskExplorer on SUN Web PortalHI,
Thanks for your answer .... We plan for a http access as the FTP port is down on our server. Is it stilling possible? Re: JDiskExplorer on SUN Web PortalOk, so you need HTTP transfer with a server-side script that will handle upload request.
Your portal server supports JSP/Servlet ? We provide a free JSP sample web application that works with JDiskExplorer. You have to install it first and make sure it works. 1 - Download JSPUpload script http://www.jfileupload.com/products/tools/index.html 2 - Install it on your server. Update upload folder path in upload.jsp. 3 - Try http://yourserver.com/somewhere/upload.jsp in your browser You have to make sure it works before installing JFileUpload + JDiskExplorer. |
