Transfer Failed
snowman18
Transfer Failed
Post by snowman18 »
I am testing out the disk explorer (i.e. not registered yet).
Everything works fine at the top level directory, but when I go to a subdirectory the transfer fails.
jfileload works on both the parent and the subdirectory?
Re: Transfer Failed
It should work with any folder. Could you check read/write permissions on directories on your FTP server?
