Since 2.7 you can enable empty username/password prompt.
Uncomment the following line in i18n_pane.properties:
panel.remote.browse.force=true
And setup the following applet parameters:
<PARAM NAME="authentication" VALUE="auto">
<PARAM NAME="username" VALUE="">
<PARAM NAME="password" VALUE="">
<PARAM NAME="param6" VALUE="disableauth">
<PARAM NAME="value6" VALUE="true">
Empty username/password promptRe: Empty username/password promptwhere can I download 2.7?
Re: Empty username/password promptnevermind... i guess your talking about java 2.7
Re: Empty username/password promptNo, it's JFileUpload 2.7 which will be available within the next weeks.
