I want to use JDiskExplorer to allow a user download files from the host. How do I specify the host directory the user can download files from? Each time I try to run JDiskExplorer, I get an empty host panel (no files listed for the host).
I am using HTTP protocol.
Thanks.
How to specify the host directory to displayRe: How to specify the host directory to displayFirst, did you install explorer.php (or explorer.jsp) on server-side ? Also, did you add the "include" line in process.php (or process.jsp) ?
Second, did you setup upload directory in process.php (or process.jsp) ? Finally, to setup a "user1" folder relative to upload directory use: <PARAM NAME="param5" VALUE="account"> <PARAM NAME="value5" VALUE="user1"> Re: How to specify the host directory to displayI did everything but was getting the following in the status line:
"Cannot change directory to /" What causes this message to be displayed? Thanks. Re: How to specify the host directory to displayCould you send a testing URL to support(at)jfileupload(dot)com ?
This error means that there is a problem with explorer.php integration. Re: How to specify the host directory to displayThanks. I am currently testing with localhost.
Which condition in explorer.jsp triggers the message: "Cannot change directory to /"? This might help me debug the code. I am using servlets instead of process.jsp and explorer.jsp. Since explorer.jsp is included in process.jsp, I had to combine both in my servlet. Any pointers to debugging the problem would help. Thanks. Re: How to specify the host directory to displayThe applet sends a custom command to change directory. This command is handled in explorer.jsp. If it does not return as expected then it displays this error message. Why not use process.jsp + explorer.jsp just for testing and make sure it works ? Then move the code to servlet.
