JDiskExplorer Remote Display
Re: JDiskExplorer Remote Display
Do you have the same error message ? Could you post it here or provide a testing URL so we could see the applet ?
Gonzalo
Post by Gonzalo »
Sorry for the delay, it was outside. Do not give me any errors not only shows me the list of directories host side, you pass the link to see what
http://www.albantacreativos.com/admin/ftp2.asp
When I upload I file, I can see the remote folder content. You want to see it as soon as the applet loads, correct ?
Gonzalo
Post by Gonzalo »
Yes, that is, as I would like to load the applet to view the content of the guidelines
Could you try to update your JavaScript by replacing:
document.writeln('<PARAM NAME="param1" VALUE="username">');
document.writeln('<PARAM NAME="value1" VALUE="YourFTPLogin">');
document.writeln('<PARAM NAME="param2" VALUE="password">');
document.writeln('<PARAM NAME="value2" VALUE="YourFTPPassword">');
by:
document.writeln('<PARAM NAME="username" VALUE="YourFTPLogin">');
document.writeln('<PARAM NAME="password" VALUE="YourFTPPassword">');
Then the applet should display the remote folder as soon as it loads.
Gonzalo
Post by Gonzalo »
Thank you very much, and it works. I wanted to ask if I can do that with all the parameters?
greetings
No, there are some regular and extra parameters. Only username/password can be setup with both.
Gonzalo
Post by Gonzalo »
thanks for your help, I work all too well
greetings
