JDiskExplorer Remote Display
import
Post by import »
I have installed JDiskExplorer and I am able to upload files, however the remote host panel is always empty (at connection time and after an upload)
After uploading a file (it's sucessfully uploaded) I get this:
INFO: Upload completed
jfileupload.transfer.client.explorer.ftp.FTPRemoteTFileSystem E
SEVERE: org.apache.commons.net.ftp.parser.ParserInitializationException: Unknown parser type: NETWARE Type: L8
What can be the problem?
import
Re: JDiskExplorer Remote Display
Post by import »
I forgot to mention that I upload to an FTPS server (AUTH TLS)
import
Post by import »
You should have the same problem with FTP (unsecured). The error you report means that the applet doesn't understand FTP server signature and then cannot parse result of a LIST directory command. Could you try to modify the FTP server signature. Usually, it's available as parameter. Try to replace the "Netware type L8" by "Unix".
import
Post by import »
That worked. However, I am only able to see the contents of the remote server after I upload something. The downloads work fine after that. How do I get an initial display of remote files?
I think the problem comes from "account" parameter. Are you using it ? Try to remove it and add:
<PARAM NAME="param6" VALUE="accountpwd">
<PARAM NAME="value6" VALUE="true">
jorgeo
Post by jorgeo »
I tried the 2.0 version and it seemed to solve this problem. Guess I'll upgrade my license to 2.0
Great !
Gonzalo
Post by Gonzalo »
have the same problem as jorgeo with version 2.4,
when loading the applet does not show the directories of the remote host, where it cools and upload a sample file directories.
Are you also using FTP with JDiskExplorer ?
Gonzalo
Post by Gonzalo »
yes, I use ftp with jdiskexplorer
