Move files
3gsVShare
Move files
Post by 3gsVShare »
We noticed the inability to 'move' files. I have checked the docs and the forums and hopefully I'm not missing anything.
Is there a way to 'move' files into folders? We've attempted to move a file into another folder, either on the remote host or on the local host, and the file does not 'move'.
Also, I posted earlier about forward=upload, ?=download.
Thank you for all of your assistance,
Byron
Re: Move files
What about if you use 'rename' and rename file1.txt as folder1/file1.txt ?
3gsVShare
Re: Move files
Post by 3gsVShare »
Thank you. That will work!
