Explorer ProblemRe: Explorer ProblemThere was another bug in folders download. It has been fixed too. I can provide a beta version if you want.
Re: Explorer ProblemI would like to try the beta. How do I get my hands on it? Based on my testing to date, I think I am ready to buy your applet. I have found a few more bugs (I will get those out to you later today or tomorrow), but overall I think it looks pretty good.
I hate to beg, but would it be also possible for you to throw into the beta two additional "user" commands that I talked about earlier to the right-click popup? If selecting one of the user commands simply sends the selected file or folder name with the user command up to the server-side script and then does a listing refresh (much like the existing delete command does) I will be set and I can then use your applet in this particular application. Thanks for your prompt responses and the help you have provided to date. Re: Explorer ProblemFor the beta please contact support(at)jfileupload(dot)com. I think we could add your feature for right click.
