Documentation of jDiskExplorer Parameters
cserold
Post by cserold »
I found the parameter listing for jFileUpload and my understanding is that jDiskExplorer has some additional parameters not included in jFileUpload. I can't find the documentation for these extra parameters for jDiskExplorer. Could you please point me in the right direction?
Craig
Re: Documentation of jDiskExplorer Parameters
cserold
Post by cserold »
Thank you but I do not see an itemized listing of the Javascript parameters that jDiskExplorer accepts that are not used by jFileUpload
It should accept all JavaScript parameters available in JFileUpload. Are you using the JSAPI ?
It can trigger a custom JavaScript. Tell me what do you want to do and I can tell if it's possible.
