Applet doesn't load
bob
Applet doesn't load
Post by bob »
Hi-
I hope you can help.
I downloaded JFileUpload, and it works great. I wanted to check out JDiskExplorer as well, but I'm having problems. I followed all the instructions, and looked through the FAQ and forums. applet_ftp_explorer.html loads, but I get a blank frame. The Apache error log says:
[Fri Apr 10 23:02:02 2009][error] [client _._._._] File does not exist: /[actual server path/web root]/jfileupload/jfileupload
[Fri Apr 10 23:02:05 2009][error] [client _._._._] File does not exist: /[actual server path/web root]/favicon.ico, referer: http://www.[my url].com/jfileupload/applet_ftp_explorer.html
Any ideas?
Thanks so much!!
Re: Applet doesn't load
Do you have an error or message displayed in the blank frame ?
Are you able to access .properties files directly in browser with:
http://server.com/something/i18n_bar.properties
bob
Post by bob »
Thanks for the quick response!
There's no message in the frame, but there's an icon in the upper left corner: a piece of paper with a red X.
It can open the 2 .properties files in the browser as text files.
Ok, so the error message is in Java console , see the following tutorial to enable Java console:
http://www.jfileupload.com/products/jfi ... oting.html
And post here the error displayed.
bob
Post by bob »
Here it is:
basic: Stopping applet…
basic: Finding information/u2026
basic: Releasing classloader: sun.plugin.ClassLoaderInfo@4a7df8, refcount=0
basic: Caching classloader: sun.plugin.ClassLoaderInfo@4a7df8
basic: Current classloader cache size: 3
basic: Done/u2026
basic: Removed progress listener: sun.plugin.util.GrayBoxPainter@4b767
basic: Joining applet thread/u2026
basic: Destroying applet…
basic: Disposing applet…
basic: Quiting applet…
basic: Joined applet thread/u2026
basic: Referencing classloader: sun.plugin.ClassLoaderInfo@4a7df8, refcount=1
basic: Loading applet/u2026
basic: Initializing applet/u2026
basic: Added progress listener: sun.plugin.util.GrayBoxPainter@1197fa
basic: Starting applet…
basic: Referencing classloader: sun.plugin.ClassLoaderInfo@4a7df8, refcount=2
basic: Releasing classloader: sun.plugin.ClassLoaderInfo@4a7df8, refcount=1
network: Connecting http://www.___.com/jfileupload/jfileupload/transfer/client/util/resources.class with proxy=DIRECT
network: Connecting http://www.___.com/jfileupload/jfileupload/transfer/client/util/resources_en.class with proxy=DIRECT
network: Connecting http://www.___.com/jfileupload/jfileupload/transfer/client/util/resources_en.properties with proxy=DIRECT
network: Connecting http://www.___.com/jfileupload/jfileupload/transfer/client/util/resources_en_US.class with proxy=DIRECT
network: Connecting http://www.___.com/jfileupload/jfileupload/transfer/client/util/resources_en_US.properties with proxy=DIRECT
network: Connecting http://www.___.com/jfileupload/jfileupload/transfer/client/core/G.class with proxy=DIRECT
basic: Exception: java.lang.NoClassDefFoundError: jfileupload/transfer/client/core/G
Thanks!
Are you sure you have jfileupload.jar in lib/ folder ?
Could you post here your ARCHIVE parameters from the JavaScript ?
The errors you get mean that some JAR files are not loaded (not available or not in ARCHIVE parameters).
bob
Post by bob »
Yes, jfileupload.jar is there. (The jfileupload applet is still working.)
ARCHIVE="lib/jfileupload.jar,lib/ftpimpl.jar,lib/cnet.jar,lib/clogging.jar,lib/explorerui.jar"
bob
Post by bob »
Well, now it's working!
And I don't know why it wasn't before. I turned java off and on, restarted the browser, and restarted the computer -- again (I had tried that before posting here) -- and it started working. It's bizarre because jfileupload was working the whole time, so I didn't think it was a java or browser issue.
I have a new computer with new software, so I wouldn't think there'd be any problems on my end, so I don't know...
I really appreciate your help and you getting back to me so quickly. Not all tech support is that responsive.
Thank you!
Great !
Maye you had a cache problem. Cleaning browser and Java cache should be enough.
