JBatchUpload on OSX 10.6.5 not initializing
Postby lillereven » Thu Dec 02, 2010 11:03 am
One customer I have would like to use the advanced batchui. Doing some tests, this works fine in Firefox 3.6.12 on Windows with Java SE 1.6.0_22 but not on Mac OSX with otherwise same version numbers. The only error message I can get out of Firefox at that point is as follows: "error: java.lang.NoSuchMethodError: jfileupload.transfer.client.util.Conf.P()Ljava/net/URL;." (see also attached screencap)
Are you aware of this issue with OSX (same for Firefox, Opera and Safari), and do you have a possible fix/workaround?
With best regards,
(9.72 KiB) Not downloaded yet
Re: JBatchUpload on OSX 10.6.5 not initializing
Postby support » Fri Dec 10, 2010 8:02 am
Could you ask him to clean his Java cache?
Applications->Utilities->Java->Delete temporary files.
Return to JBatchUpload
