Folder Choice
BioTek
Folder Choice
Post by BioTek »
Is it possible to create a html drop down list form for folder upload choice instead of a fixed folder in the account parameter.
Re: Folder Choice
Yes, I think so. You can use the JavaScript API.
1/ The applet must be loaded
2/ You write some JavaScript in your HTML dropdown list that notifies the applet
document.fileupload.setParameter("account",something.like.dropdownlist.value);
3/ When end-user starts upload the new "account" parameter modified with JavaScript should be taken into account.
Does it help ?
BioTek
Re: Folder Choice
Post by BioTek »
Yes,
Thank you.
