Erroneous status bar message "Upload completed (N files)", but file wan't actually completed, it wasn't even found.
steps to reproduce
1. Add a file to jBatchUpload
2. Move/Rename this file in the file system
3. Slick "start upload"
BUG in jBatchUpload - file not found, but shows "uploaded"Re: BUG in jBatchUpload - file not found, but shows "uploaded"If you move rename the file safter selection then you have to clean selection and select the new files again.
Re: BUG in jBatchUpload - file not found, but shows "uploaded"I understand that what you're saying is a workaround.
But I believe that if a file can't be found, code should return an error instead of of saying "uploaded", which is very misleading. Re: BUG in jBatchUpload - file not found, but shows "uploaded"Yes. We're going to add such checks.
Re: BUG in jBatchUpload - file not found, but shows "uploaded"In v.2.5? Can't wait.
Meanwhile I'm attaching my fix, see if you like it. Re: BUG in jBatchUpload - file not found, but shows "uploaded"2.5 has been release last week. Drop an email with your tracking ID to get it.
