process.php
CortoMaltese
process.php
Post by CortoMaltese »
Hi
is t possible to use JBatchUpload whe using process.php ?
It seem that i added all the files and did the right installation things
The applet still doesnt load
Corto
Re: process.php
Sure, process.php woriks with JFileUpload, JBathcUpload, JImageUpload and JImageFilter.
CortoMaltese
Re: process.php
It does not work for me>....
the java console says :
INFO: JBatchUpload 2.4 FINAL.001
Exception in thread "thread applet-jfileupload.upload.client.MApplet.class-2" java.lang.NoSuchMethodError: jfileupload.transfer.client.util.Conf.L(Ljava/lang/String;)Ljava/lang/String;
   at jfileupload.transfer.client.edesign.BatchTransferUI.A(Unknown Source)
   at jfileupload.upload.client.MApplet.loadUI(Unknown Source)
   at jfileupload.upload.client.MApplet.init(Unknown Source)
Any idea ?
Re: process.php
Yes, do you have any Premium or Enterprise version ? The error you reports is a mismatch between applet version or package. For instance, you're trying to use JBatchUpload pro with JFileUpload enterprise or JBatchUpload Pro 2.4 with JFileUpload Pro 2.3.
CortoMaltese
Re: process.php
I use JfileUpload 2.5 RC1 (with the license of 2.4 pro)
with JBatchUpload pro 2.4
Re: process.php
Drop an email to support(at)jfileupload(dot)com to get JBatchUpload 2.5RC1 too.
CortoMaltese
Re: process.php
Just did :)
