I'm not being able to build the jbatchupload from source code using ant. I have attached the logs for reference. I have the lib directory in the same folder as build.xml and it contains following jar files.
chttpclient, clogging and cnet. I was able to build jfileupload successfully though.
Please advice on how to proceed.
Buildfile: C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\build.xml
init:
[echo] ---------------------------------------------------------------
[echo] ----------- BUILDING JFILEUPLOAD PACKAGE ---------
[echo]
clean:
[echo] ------ Cleaning ...
[delete] Deleting directory C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\classes
[mkdir] Created dir: C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\classes
[delete] Deleting directory C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\dist\lib
[mkdir] Created dir: C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\dist\lib
build.core:
[echo] ------ Compiling application - Front-end
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\build.xml:90: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 10 source files to C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\classes
[javac] warning: [options] bootstrap class path not set in conjunction with -source 1.3
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:37: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.ClientException;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:38: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.CompressListener;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:39: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.FilterListener;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:40: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.SplitListener;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:41: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.TransferController;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:42: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.TransferListener;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:43: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.TransferUI;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:44: error: package jfileupload.transfer.client.mdesign does not exist
[javac] import jfileupload.transfer.client.mdesign.FileBrowser;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:45: error: package jfileupload.transfer.client.mdesign does not exist
[javac] import jfileupload.transfer.client.mdesign.MenuBar;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:46: error: package jfileupload.transfer.client.mdesign does not exist
[javac] import jfileupload.transfer.client.mdesign.ProgressPanel;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:47: error: package jfileupload.transfer.client.util does not exist
[javac] import jfileupload.transfer.client.util.Conf;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:48: error: package jfileupload.transfer.client.util does not exist
[javac] import jfileupload.transfer.client.util.CustomResourceBundle;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:56: error: cannot find symbol
[javac] public class BatchTransferUI extends JPanel implements TransferUI, TransferListener, CompressListener, FilterListener, SplitListener, ActionListener
[javac] ^
[javac] symbol: class TransferUI
[javac] ^
[javac] symbol: class TransferListener
[javac] ^
[javac] symbol: class CompressListener
[javac] ^
[javac] symbol: class FilterListener
[javac] ^
[javac] symbol: class SplitListener
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:63: error: cannot find symbol
[javac] private TransferController controller = null;
[javac] ^
[javac] symbol: class TransferController
[javac] location: class BatchTransferUI
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:64: error: cannot find symbol
[javac] private Conf cnf = null;
[javac] ^
[javac] symbol: class Conf
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:65: error: cannot find symbol
[javac] private CustomResourceBundle bundle = null;
[javac] ^
[javac] symbol: class CustomResourceBundle
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:60: error: package jfileupload.transfer.client.core does not exist
[javac] import jfileupload.transfer.client.core.AbstractTransferController;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:61: error: package jfileupload.transfer.client.core does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:21: error: package jfileupload.transfer.client.core does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:22: error: package jfileupload.transfer.client.core does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:23: error: package jfileupload.transfer.client.core does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:63: error: package jfileupload.transfer.client.mdesign does not exist
[javac] import jfileupload.transfer.client.mdesign.ImageViewport;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:64: error: package jfileupload.upload.client does not exist
[javac] import jfileupload.upload.client.MApplet;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:18: error: package jfileupload.transfer.client.core does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:19: error: package jfileupload.transfer.client.mdesign does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:20: error: package jfileupload.transfer.client.util does not exist
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:22: error: cannot find symbol
[javac] public class UploadProgress extends ProgressPanel
[javac] ^
[javac] symbol: class ProgressPanel
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:70: error: cannot find symbol
[javac] private FileBrowser fbrowser = null;
[javac] ^
[javac] symbol: class FileBrowser
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:85: error: cannot find symbol
[javac] public boolean init(Container parent, Conf cnf, TransferController transferc)
[javac] ^
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:433: error: cannot find symbol
[javac] public TransferController getController()
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:472: error: cannot find symbol
[javac] public String getErrorMessage(ClientException e)
[javac] ^
[javac] symbol: class ClientException
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:558: error: cannot find symbol
[javac] public void transferFailed(ClientException e)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:619: error: cannot find symbol
[javac] public void filterFailed(ClientException e)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:640: error: cannot find symbol
[javac] public void compressFailed(ClientException e)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:694: error: cannot find symbol
[javac] public void splitFailed(int chunkid, ClientException e)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:929: error: cannot find symbol
[javac] protected boolean isAllowed(String filename) throws ClientException
[javac] ^
[javac] location: class QueuePanel
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:31: error: cannot find symbol
[javac] private TransferController transferController = null;
[javac] ^
[javac] location: class CustomTableModel
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:42: error: cannot find symbol
[javac] public TransferController getTransferController()
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:47: error: cannot find symbol
[javac] public void setTransferController(TransferController transferController)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:85: error: cannot find symbol
[javac] public FolderInfo getFolderInfo(File file) throws ClientException
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:92: error: cannot find symbol
[javac] public void addFile(File file) throws ClientException
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:30: error: cannot find symbol
[javac] public UploadProgress(Conf cnf)
[javac] ^
[javac] location: class UploadProgress
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:106: error: cannot find symbol
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:187: error: cannot find symbol
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:315: error: cannot find symbol
[javac] public void countFiles(File directory) throws ClientException
[javac] ^
[javac] location: class CustomTableModel.FolderInfo
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:329: error: cannot find symbol
[javac] private void countFilesRecursively(File file) throws ClientException
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:373: error: cannot find symbol
[javac] private boolean isAllowed(File file) throws ClientException
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:98: error: cannot find symbol
[javac] this.bundle = new CustomResourceBundle(true);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:102: error: cannot find symbol
[javac] this.bundle = new CustomResourceBundle(false);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:151: error: inconvertible types
[javac] int xspacing = (int) cnf.getLong(getResource("queue.buttons.panel.layout.spacing.x"));
[javac] ^
[javac] required: int
[javac] found: getLong
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:152: error: inconvertible types
[javac] int yspacing = (int) cnf.getLong(getResource("queue.buttons.panel.layout.spacing.y"));
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:176: error: no suitable method found for add(UploadProgress,GridBagConstraints)
[javac] add(progress, cns);
[javac] ^
[javac] method Container.add(Component,Object,int) is not applicable
[javac] (actual and formal argument lists differ in length)
[javac] method Container.add(Component,Object) is not applicable
[javac] (actual argument UploadProgress cannot be converted to Component by method invocation conversion)
[javac] method Container.add(Component,int) is not applicable
[javac] method Container.add(String,Component) is not applicable
[javac] (actual argument UploadProgress cannot be converted to String by method invocation conversion)
[javac] method Container.add(Component) is not applicable
[javac] method Component.add(PopupMenu) is not applicable
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:189: error: no suitable method found for add(UploadProgress,GridBagConstraints)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:195: error: no suitable method found for add(UploadProgress,String)
[javac] add(progress, BorderLayout.SOUTH);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:202: error: cannot find symbol
[javac] String source = cnf.getProperty(Conf.TEMPLATEITEM + (i++));
[javac] ^
[javac] symbol: variable Conf
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:228: error: cannot find symbol
[javac] if ((bar != null) && (bar instanceof MenuBar))
[javac] ^
[javac] symbol: class MenuBar
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:230: error: cannot find symbol
[javac] MenuBar menubar = (MenuBar) bar;
[javac] ^
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:235: error: cannot find symbol
[javac] fbrowser = new FileBrowser(cnf);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:269: error: cannot find symbol
[javac] progress.getFileProgressBar().setString(empty);
[javac] ^
[javac] symbol: method getFileProgressBar()
[javac] location: variable progress of type UploadProgress
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:273: error: cannot find symbol
[javac] else if ((ae.getActionCommand().equals(cnf.getResource("menu.file.open"))) || (ae.getActionCommand().equals(cnf.getResource("menu.file"))) || (ae.getActionCommand().equals(ProgressPanel.SELECT_AC)))
[javac] ^
[javac] symbol: variable ProgressPanel
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:298: error: cannot find symbol
[javac] progress.getFileProgressBar().setString(MessageFormat.format(txt, args));
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:302: error: cannot find symbol
[javac] else progress.getFileProgressBar().setString(MessageFormat.format(txt, args));
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:326: error: cannot find symbol
[javac] if (bfactor != null) progress.applyFontFactor(progress.getFileProgressBar(), bfactor);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:328: error: cannot find symbol
[javac] if (bstyle != null) progress.applyFontStyle(progress.getFileProgressBar(), bstyle);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:335: error: cannot find symbol
[javac] progress.getFileProgressBar().setString(text);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:337: error: cannot find symbol
[javac] selectButton = progress.getSelectButton();
[javac] ^
[javac] symbol: method getSelectButton()
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:342: error: cannot find symbol
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:345: error: method removeActionListener in class AbstractButton cannot be applied to given types;
[javac] selectButton.removeActionListener(progress);
[javac] ^
[javac] required: ActionListener
[javac] found: UploadProgress
[javac] reason: actual argument UploadProgress cannot be converted to ActionListener by method invocation conversion
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:390: error: cannot find symbol
[javac] if (progress.getCancelButton() == null)
[javac] ^
[javac] symbol: method getCancelButton()
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\BatchTransferUI.java:613: error: package TransferController does not exist
[javac] if ((target != null) && (target instanceof File) && (TransferController.PREPROCESSING_FILTER.equalsIgnoreCase(custom)))
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\CustomTableModel.java:378: error: cannot find symbol
[javac] ret = ((AbstractTransferController) transferController).isAllowed(file);
[javac] ^
[javac] symbol: class AbstractTransferController
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:376: error: cannot find symbol
[javac] ImageViewport vp = new ImageViewport(bck);
[javac] ^
[javac] symbol: class ImageViewport
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:431: error: cannot find symbol
[javac] if ((filesonly != null) && (filesonly.equalsIgnoreCase("filesonly"))) throw new ClientException(ClientException.DIRNOTALLOWED, file.getAbsolutePath());
[javac] ^
[javac] ^
[javac] symbol: variable ClientException
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:438: error: cannot find symbol
[javac] throw new ClientException(ClientException.FULLSIZENOTALLOWED,String.valueOf(fullmaxsize));
[javac] ^
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:443: error: cannot find symbol
[javac] throw new ClientException(ClientException.SIZENOTALLOWED,String.valueOf(maxsize));
[javac] ^
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:448: error: cannot find symbol
[javac] throw new ClientException(ClientException.TOOMANYFILES,String.valueOf(maxfiles));
[javac] ^
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:454: error: cannot find symbol
[javac] catch (ClientException e)
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:607: error: cannot find symbol
[javac] if ((topParent != null) && (topParent instanceof MApplet))
[javac] ^
[javac] symbol: class MApplet
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:614: error: cannot find symbol
[javac] ((MApplet) topParent).notifyJS(jsNotification, params, null);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\QueuePanel.java:931: error: cannot find symbol
[javac] return ((AbstractTransferController) loader.getController()).isAllowed(new File(filename));
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:33: error: cannot find symbol
[javac] upLabel = uploadLabel;
[javac] ^
[javac] symbol: variable uploadLabel
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:53: error: cannot find symbol
[javac] return super.bpanel;
[javac] ^
[javac] symbol: variable super
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:58: error: cannot find symbol
[javac] return super.bpanelcnts;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:63: error: cannot find symbol
[javac] super.bpanel = pane;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:70: error: cannot find symbol
[javac] super.transferTriggered(files, type);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:75: error: cannot find symbol
[javac] super.transferStarted(source, contentlength);
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:84: error: cannot find symbol
[javac] uploadLabel = MessageFormat.format(chunkPattern, new Object[] { upLabel, new Integer(chunkid), new Long(chunks) });
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:92: error: cannot find symbol
[javac] else uploadLabel = upLabel;
[javac] ^
[javac] C:\Users\Tejas\Downloads\j3.2\jfileuploadpremium3.2\src\jfileupload\transfer\client\edesign\UploadProgress.java:93: error: cannot find symbol
[javac] super.dataRead(read);
[javac] ^
[javac] 100 errors
[javac] 1 warning
