TaskOutput whitelist ErrorTaskOutput whitelist ErrorWhen I am using BatchUpload, If I am dragging the files the files whoes extension are not allowed shows only the last one which is not allowed..Is there anyway to show all the files which are not allowed and show only the file name rather than the full folder and file path?? Because if it is a big folder path user really cann't see..
Re: TaskOutput whitelist ErrorNo sorry, it requires source code customization.
Re: TaskOutput whitelist ErrorAppreciate your reply.So there is no way I can specify only filename rather than the whole filename in i18n_bar.properties??
Re: TaskOutput whitelist ErrorNo, all is in the following line:
taskoutput.upload.failed.whitelist.error=Denied : File extension not allowed for {0} You can remove the file info if you replace it by: taskoutput.upload.failed.whitelist.error=Denied : File extension not allowed |
