Currently I'm using the unregistered version to see if I can make this work....
Problem is as follows:
I have used jupload with the JDiskExplorer frontend, and when I upload a folder, the folder gets created under the account specified.
However, if I use JBatchUpload, I get a cannot change directory error. I can't work out why...
here's the code i'm using ( i tried countless variations too) any help much appreciated...
<param name="hidebar" value="false">
<param name="url" value="ftp://xxx.xxx.xxx.xxx">
<param name="param1" value="username">
<param name="value1" value="xxx">
<param name="param2" value="password">
<param name="value2" value="xxx">
<param name="param3" value="pasv">
<param name="value3" value="true">
<param name="param4" value="account">
<param name="value4" value="1190712456_46">
<param name="param5" value="relativefilename">
<param name="value5" value="true">
<param name="folderdepth" value="-1">
<param name="forward" value="a url">
<param name="transferui" value="jfileupload.transfer.client.batchdesign.ETransferUI">
<param name="transferuiresources" value="i18n_pane">
<param name="resources" value="i18n_bar">
<param name="mode" value="ftp">
creating foldersRe: creating foldersDouble check the "account" parameter. You might have it starting (or ending) with "/" in JDiskExplorer. Also make sure you're using the same FTP account with same read/write permissions.
Re: creating foldersHi,
thanks for the reply. I am however using the same account parameters and the same ftp account... I even tried to use the same parameters that worked for JDiskExplorer with the BatchUpload, (except transferui of course ), and it still told me that it cannot change directories . Any other hints greatly appreciated Olly Re: creating foldersCould you provide a testing URL with the JBatchUpload applet to support(at)jfileupload(dot)com ?
I've sent you an email re testing version thanks Re: creating foldersYeap, problem reproduced. Minor "account" parameter different behavior. Two solutions:
- Solution 1: Absolute path <PARAM NAME="param4" VALUE="account"> <PARAM NAME="value4" VALUE="/rootfolder/folder1"> - Solution 2: accountpwd parameter and account starting with / <PARAM NAME="param4" VALUE="account"> <PARAM NAME="value4" VALUE="/folder1"> <PARAM NAME="param8" VALUE="accountpwd"> <PARAM NAME="value8" VALUE="true"> Re: creating foldersExcellent. That works. (solution2 anyway)
(for someone who might be as stupid as I am : As my ftp account doesn't have any other password(s) for subfolders, I wondered what the accountpwd should be. Turns out it just needs to be "true" .... DOH ! ) Re: creating folders"accountpwd" allows issuing a PWD FTP command before trying to change directory to the one setup in "account" parameter. PWD just return the current directory.
