I don't seem to be getting EXIF data even with #metadata=unknownmarker (or #metadata=all). At first I thought that scaling.properties was not reloading but I have verified that other parameters are being read. Is there another parameter that needs to be set?
Additional...tried on another server and client combination, WAMP and IE instead of MAMP and Firefox. Still no EXIF data.
Thanks in advance, Will
No Exif even with #metadataRe: No Exif even with #metadataDid you uncomment:
#metadata=unknownmarker as: metadata=unknownmarker Could you post a testing image so we could try to reproduce the problem here?
Re: No Exif even with #metadataOMG. This is where I slink off into the woodwork of this message board never to be seen again. With a red face. The parameter works much better when it is not a comment. I had even messed with other parameters (uncommented ones) and not managed to figure this out myself.
Thanks for the response. Will |
