Original source image deleted
Image scaler add-on.
Postby kiki » Fri Mar 04, 2011 9:59 am
Using jmagefilter, images sent from the source folder are deleted.
Why?
kiki
Re: Original source image deleted
Postby support » Sun Mar 06, 2011 7:50 pm
They should not be deleted except if you've enable an option for so. Could you provide here your JavaScript and scaling.properties file?
Postby kiki » Mon Mar 07, 2011 10:32 am
This is my scaling file:
# Image filter properties.
maxwidth=2000
maxheight=1500
# Optional scaling properties for landscape and portrait.
landscape.maxwidth=2000
landscape.maxheight=1500
portrait.maxwidth=1500
portrait.maxheight=2000
# Scale option (allowmagnify or fitaspectratio)
# allowmagnify: Magnify image if size < maxwidth and maxheight parameters above.
# fitaspectratio: Modify aspect ratio to fit image dimension to maxwidthxmaxheight
#scaleoption=allowmagnify
# scalefactor allows to reduce or magnify image regardless to
# maxwidth and maxheight parameters above.
#scalefactor=0.5
# quality allows to select compression quality from 0.0 to 1.0
#quality=0.8
# Forward input metadata to scaled image (unknownmarker or all)
# metadata=all
# Abort action on metadata issue (default is ignore)
#metadata.error=abort
# Watermark image (Use transparent PNG with dimensions < maxwidth x maxheight)
# Watermark locations are: center, topleft, topright, topcenter, bottomleft, bottomright, bottomcenter
#watermarklocation=bottomright
# Watermark transparency factor from 0.0 to 1.0 (1.0 means no transparency)
#watermarkfactor=0.3
# Temporary folder (if not available then it will use user's home. Use auto for same folder as original image)
#tmpfolder=c:/temp
# Scaled image filename. Values could be "append" or "rename" or "renameifneeded"
renamepolicy=append
# Supported input image formats for scaling.
#For JRE 1.4 without IO Tools.
#extensions=jpg,jpeg,jpe,gif,png
#For JRE 1.5 without IO Tools.
#extensions=jpg,jpeg,jpe,gif,png,bmp
#For JRE 1.4 or 1.5 with IO Tools.
#extensions=jpg,jpeg,jpe,gif,png,bmp,tif,tiff,pnm,raw
# Force RGB conversion.
forcergb=true
# SUN Bug 4881314 workaround.
#imageloader=toolkit
# Scaling implementation (AWT, ImageIO or ImageIOSubsample). Default is ImageIO.
#impl=awt
# Multi-step approach for best image quality with ImageIO scaling implementation.
#multistep=true
# Output image format after scaling (same as input if commented).
# GIF outformat is not available.
outformat=jpg
# Rotation algorithm (nearestneighbor, bilinear, bicubic). Default is bicubic
#rotation.algorithm=nearestneighbor
# Misc
# Disable filter for image dimensions > maxpixels
#maxpixels=9000000
# Disable filter for image with width <= maxwidth or height <= maxheight
#disable.maxwidth=640
#disable.maxheight=480
# Stop upload on image operation error (default is ignore).
#operation.error=abort
# Enable filterparamX/filtervalueX reloading.
#enable=true
And this is my javascript.
Please consider only the part concerning INTERNET EXPLORER, the first part is not yet complete.
However the problem occurs only by applying the scaling file.
var _info = navigator.userAgent;
var _ns = false;
var _ns6 = false;
var _ie = (_info.indexOf("MSIE") > 0 && _info.indexOf("Win") > 0 && _info.indexOf("Windows 3.1") < 0);
if (_info.indexOf("Opera") > 0) _ie = false;
var _ns = (navigator.appName.indexOf("Netscape") >= 0 && ((_info.indexOf("Win") > 0 && _info.indexOf("Win16") < 0) || (_info.indexOf("Sun") > 0) || (_info.indexOf("Linux") > 0) || (_info.indexOf("AIX") > 0) || (_info.indexOf("OS/2") > 0) || (_info.indexOf("IRIX") > 0)));
var _ns6 = ((_ns == true) && (_info.indexOf("Mozilla/5") >= 0));
if (_ie == true) {
  document.writeln('<OBJECT classid="clsid:8AD9C840-044E-11D1-B3E9-00805F499D93" WIDTH="640" HEIGHT="350" NAME="fileupload" codebase="http://java.sun.com/update/1.4.2/jinstall-1_4-windows-i586.cab#Version=1,4,0,0">');
else if (_ns == true && _ns6 == false) {
  // BEGIN: Update parameters below for NETSCAPE 3.x and 4.x support.
  document.write('<EMBED ');
  document.write('type="application/x-java-applet;version=1.4" ');
  document.write('CODE="jfileupload.upload.client.MApplet.class" ');
  document.write('JAVA_CODEBASE="./" ');
  document.write('ARCHIVE="lib/jfileupload.jar,lib/ftpimpl.jar,lib/cnet.jar,lib/clogging.jar,lib/previewui.jar,lib/ifilter.jar,lib/jai_imageio.jar" ');
  document.write('NAME="fileupload" ');
  document.write('WIDTH="640" ');
  document.write('HEIGHT="350" ');
  document.write('url="ftp.mysite.biz" ');
  document.write('username="myusername" ');
  document.write('password="mypassword" ');
  document.write('param3="pasv" ');
  document.write('value3="true" ');
  document.write('param4="account" ');
  document.write('value4="./upload/13x18" ');
  document.write('transferui="jfileupload.transfer.client.preview.PreviewerTransferUI" ');
  document.write('resources="1318_bar" ');
  document.write('transferuiresources="1318_pane" ');
  document.write('mode="ftp" ');
  document.write('scriptable=true ');
 document.writeln('pluginspage="http://java.sun.com/products/plugin/index.html#download"><NOEMBED>');
  // END
else {
  document.write('<APPLET CODE="jfileupload.upload.client.MApplet.class" JAVA_CODEBASE="./" ARCHIVE="lib/jfileupload.jar,lib/ftpimpl.jar,lib/cnet.jar,lib/clogging.jar,lib/previewui.jar,lib/ifilter.jar,lib/jai_imageio.jar" WIDTH="640" HEIGHT="350" NAME="fileupload">');
// BEGIN: Update parameters below for INTERNET EXPLORER, FIREFOX, SAFARI, OPERA, MOZILLA, NETSCAPE 6+ support.
document.writeln('<PARAM NAME=ARCHIVE VALUE="lib/jfileupload.jar,lib/ftpimpl.jar,lib/cnet.jar,lib/clogging.jar,lib/previewui.jar,lib/ifilter.jar,lib/jai_imageio.jar">');
document.writeln('<PARAM NAME="url" VALUE="ftp://ftp.mysite.biz">');
document.writeln('<PARAM NAME="param1" VALUE="username">');
document.writeln('<PARAM NAME="value1" VALUE="myusername">');
document.writeln('<PARAM NAME="param2" VALUE="password">');
document.writeln('<PARAM NAME="value2" VALUE="mypassword">');
document.writeln('<PARAM NAME="param4" VALUE="account">');
document.writeln('<PARAM NAME="value4" VALUE="./upload/13x18">');
document.writeln('<PARAM NAME="param3" VALUE="pasv">');
document.writeln('<PARAM NAME="transferui" VALUE="jfileupload.transfer.client.preview.PreviewerTransferUI">');
document.writeln('<PARAM NAME="resources" VALUE="1318_bar">');
document.writeln('<PARAM NAME="transferuiresources" VALUE="1318_pane">');
document.writeln('<PARAM NAME="mode" VALUE="ftp">');
document.writeln('<PARAM NAME="folderdepth" VALUE="-1">');
document.writeln('<PARAM NAME="hidebar" VALUE="false">');
document.writeln('<PARAM NAME="param5" VALUE="relativefilename">');
document.writeln('<PARAM NAME="VALUE5" VALUE="TRUE">');
document.writeln('<PARAM NAME="policy" VALUE="ignore">');
document.writeln('<PARAM NAME="resume" VALUE="TRUE">');
document.writeln('<PARAM NAME="filterparam1" VALUE="tmpfolder">');
document.writeln('<PARAM NAME="filtervalue1" VALUE="auto">');
document.writeln('<PARAM NAME="filter" VALUE="jfileupload.upload.client.filter.ImageFilter">');
document.writeln('<PARAM NAME="filterproperties" VALUE="1318_scaling.properties">');
document.writeln('<PARAM NAME="forward" value="http://www.mysite.biz/formail.htm">');
// END
if (_ie == true) {
  document.write('</OBJECT>');
  document.write('</NOEMBED></EMBED>');
else {
  document.write('</APPLET>');
Thanks for the help
kiki
Postby support » Mon Mar 07, 2011 6:31 pm
Could you try to remove:
And see if the problem still occurs?
Return to JImageFilter
cron
