Image resizing failing with jpeg 300x300dpi and 32 bit depth
Image scaler add-on.
Postby andrea » Wed Nov 10, 2010 5:13 pm
Hi
I'm facing this strange error with two images (6 MB weight) 2600x2814 with 300x300 dpi HxV resolution and 32 bit color depth. This images causes JImageUpload and JImageFilter to crash so no local resizing occurs.
any clue?
TIA
ANdrea
andrea
Re: Image resizing failing with jpeg 300x300dpi and 32 bit depth
Postby support » Wed Nov 10, 2010 10:17 pm
Could you try to increase Java heap size:
<PARAM NAME="java_arguments" VALUE="-Xmx384m">
Postby andrea » Thu Nov 11, 2010 4:56 pm
no way. No preview and no scaling occurs.
andrea
Postby andrea » Thu Nov 11, 2010 5:40 pm
Hi
I think that 32 bit color depth is not supported, whatever heap size i set.
andrea
Postby support » Sun Nov 14, 2010 7:50 pm
Could you send a sample image to support(at)jfileupload(dot)com
Postby support » Sun Nov 28, 2010 4:13 pm
<PARAM NAME="java_arguments" VALUE="-Xmx384m"> works under FireFox + Internet Explorer under Windows but under MacOSX it requires latest Java update 1.6.0_22 with "run in their own process" option enabled. See screenshot.
Java console MACOSX
(50.31 KiB) Not downloaded yet
Return to JImageFilter
