Image quality on resized images
Image scaler add-on.
Postby dstonek » Thu Apr 24, 2008 8:02 pm
I cannot see differences between setting 'quality=0' or 'quality=1' in scaling.properties.
I set 0.8 by default but I see artifacts on people faces so I made some test on extreme values.
Is there something I am missing?
I am resizing from 12Mp to 500 pixels max size.
The differences between this photos and the Irfanview's (a nice program to handle images) generated ones are appreciable.
Thank you
PS: In all quality setting the jpeg file size is 35Kb Irfanview's 42Kb (80/100 qual)
dstonek
Re: Image quality on resized images
Postby support » Thu Apr 24, 2008 8:23 pm
Try values from 0.05 to 1.0, you will see the differences. For 0.1, JPEG compression is good but image quality is very bad. For 1.0, quality is perfect but image size is big.
Postby dstonek » Thu Apr 24, 2008 10:18 pm
I aaaaalways forget to clean the java cache. To do this in Firefox I have to close and open the program.
500x380 pixels takes around 174kb (this image) in quality 1
35Kb in quality 0.6
49Kb in quality 0.8
Is it possible to control sharpening amount?
I would prefer less filtering.
Thank you.
dstonek
Postby support » Fri Apr 25, 2008 8:03 am
No, this feature is not available. But it could be a good idea. Do you a have link that explain the basics of such filtering ?
Postby dstonek » Fri Apr 25, 2008 12:16 pm
Well, I've read something about sharpening several years ago but I don't have a modern link.
dstonek
Postby support » Sun Apr 27, 2008 12:20 pm
I've found this one:
http://www.photoshopsupport.com/tutoria ... ening.html
Does it fit to your definition ?
Return to JImageFilter
cron
