After resize I found that a couple of B&W photos went brighter than their original files.
Try this one
or
This one
Resizing Black and White photosRe: Resizing Black and White photosYes, we've noticed this issue with some grayscale images. We're trying to fix it.
Re: Resizing Black and White photosHave you solved this problem? Maybe they have to be converted to rbg. Is it posible in Java?
Re: Resizing Black and White photosYes, this problem has been solved. I've sent you an email with a link to download the updated version with the fix. Update all JAR files in lib/ folder, clean browser cache, clean Java cache, close all browser windows and try again.
Does it work ? Re: Resizing Black and White photosYes!
Nice! Samples are intended to show online, then, converting them to RGB for resize is a logical way. This is v2.2beta2 version of this product. Re: Resizing Black and White photosYes....Awesome i am interested
Re: Resizing Black and White photosJust try release 2.8.
