Apply a image filter just for some images
Image scaler add-on.
import
Post by import »
Is it possible to scale just the images which are higher than the
maxwidth and maxheight and not all the images ?
import
Re: Apply a image filter just for some images
Post by import »
Yes, that's the way JImageFilter works. It checks:
maxwidth & maxheight
then:
landscape.maxwidth and landscape.maxheight
then:
portrait.maxwidth and portrait.maxheight
Depending on values above, it won't scale incoming images.
import
Post by import »
When I upload an image jpg which size is lower than the maxwidth
or maxheight. This images are saving again with the indication
"unregistred". And the quality of images is deteriorate for the
compression.
My scaling filter configuration is :
maxwidth=640
maxheight=480
quality=0.9
renamepolicy=rename
extensions=jpg,jpeg,jpe,bmp,tif,tiff,pnm,raw
forcergb=true
outformat=jpg
import
Post by import »
Ok, you want no modification at all. For instance, if you upload a GIF then it must stay in GIF format, correct ? Because the image filter convert all in output format (jpg here) and apply quality parameter, meta data (EXIF) cut or forward ...
import
Post by import »
yes, exactly ! and I understand but ... I would like this configuration
Tiff -> jpg
Raw-> jpg
Png -> png
Gif -> png
Jpeg -> jpg
and when I upload an image which size is lower than the maxwidth
and maxheight : no touch, just dropped !
It's possible with the version 2 ?
import
Post by import »
Mmmmhh, you're request is quite specific. We only planned one output format whatever the input. If you need this feature then you will need a custom development.
import
Post by import »
ok, I understand.
Thank you
