Can I get an example on how to capture/handle javascript event when file transfer completes?
I downloaded JSAPI and the example is for HTTP upload but I am using FTP upload.
I tried to use JSTransferDone method but I think it needs to be registered first but I don't know how it work for ftp.
Jitin
javascript notification when file upload completesjavascript notification when file upload completes
Re: javascript notification when file upload completesYou have to adapt the HTTP sample to FTP. Here are instructions:
1 - Declare JAR files for FTP instead of HTTP: You have the replace the 3 occurrences of the line below: lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar,lib/jsapi.jar must be replaced by: lib/jfileupload.jar,lib/ftpimpl.jar,lib/cnet.jar,lib/clogging.jar 2 - Switch mode parameter to FTP: document.writeln('<PARAM NAME="mode" VALUE="http">'); document.write('mode="http" '); becomes: <PARAM NAME="mode" VALUE="ftp"> document.write('mode="ftp" '); 3 - Remove HTTP transfer related lines: document.writeln('<PARAM NAME="paramfile" VALUE="uploadfile">'); document.writeln('<PARAM NAME="param1" VALUE="todo">'); document.writeln('<PARAM NAME="value1" VALUE="upload">'); and: document.write('paramfile="uploadfile" '); document.write('param1="todo" '); document.write('value1="upload" '); 4 - Replace HTTP URL with FTP URL: document.writeln('<PARAM NAME="url" VALUE="http://localhost:8080/upload/process.jsp">'); document.write('url="http://localhost:8080/upload/process.jsp" '); by: document.writeln('<PARAM NAME="url" VALUE="ftp://localhost">' document.write('url="ftp://localhost" '); 5 - Setup FTP username/password: document.writeln('<PARAM NAME="param1" VALUE="username">'); document.writeln('<PARAM NAME="value1" VALUE="yourFTPusername">'); document.writeln('<PARAM NAME="param2" VALUE="password">'); document.writeln('<PARAM NAME="value2" VALUE="yourFTPpassword">'); document.writeln('<PARAM NAME="param1" VALUE="username">' document.write('value1="yourFTPusername" '); document.writeln('<PARAM NAME="param2" VALUE="password">' document.write('value2="yourFTPpassword" '); Please try it and let me know if it helps. Re: javascript notification when file upload completesThanks for your reply but this is not what I am looking for.
I am already using applet in ftp mode but th problem is using JSAPI in ftp mode. None of the javascrupt events or methods defined in http example are firing when I convert it to ftp. More specifically I am interested in catching JSTransferDone event. Any help would be appreciated. Thanks Jitin Re: javascript notification when file upload completesIt should. Please post here your script for FTP. You may forget the MAYSCRIPT tag that allows notification.
