jupload resume
import
jupload resume
Post by import »
I'm using jupload 1.9.3 with the php scripts from your site. I finally managed to get the resume working (setting the monitor keyword AND the resume). Now, when i select 10 files for upload and it fails at file 5, then the resume works. But, it starts all over at file one. Can I configure the applet so that it restarts at the last file?
import
Re: jupload resume
Post by import »
Yes, but with a new "retry" that will be available in 2.0. If you want to test it then contact support(at)jfileupload(dot)com
