Exception uploading from read-only mediaException uploading from read-only mediaWhen we upload files from a read-only media we are getting an IO exception. This could be because the applet is trying to write chunks / zip file locally directly onto the read-only media.
Any work-arounds for this? We could possibly specify the default java tmp folder for this purpose? Here is the exception: java.io.FileNotFoundException: E:\VIDEO_TS\VIDEO_TS.VOB.zip (Access is denied) at java.io.FileOutputStream.open(Native Method) at java.io.FileOutputStream.<init>(Unknown Source) at java.io.FileOutputStream.<init>(Unknown Source) at jfileupload.transfer.client.B.E.A(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.I(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.C(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Jun 11, 2008 9:12:31 AM jfileupload.transfer.client.http.HTTPUploadTransfer J INFO: Split triggered Jun 11, 2008 9:12:31 AM jfileupload.transfer.client.http.HTTPUploadTransfer J INFO: Split started 1/11 Jun 11, 2008 9:12:31 AM jfileupload.transfer.client.http.HTTPUploadTransfer J SEVERE: java.io.FileNotFoundException: E:\VIDEO_TS\VIDEO_TS.VOB.1 (Access is denied) Jun 11, 2008 9:12:31 AM jfileupload.transfer.client.http.HTTPUploadTransfer run INFO: Upload failed Re: Exception uploading from read-only mediaTry:
<PARAM NAME="chunkmode" VALUE="onfly"> It won't generate chunks on disk and it will be quite faster. Does it help ? Re: Exception uploading from read-only mediaWell the documentation of that parameter says "...This parameter isn't allowed when resume support is enabled. "
We do need resume support as well as compression. Re: Exception uploading from read-only mediaI see. A workaround could be to setup tmpfolder parameter. It should generate the files in the local tmp dir. Try: <PARAM NAME="tmpfolder" VALUE="javatmpdir">
Does it help ? Re: Exception uploading from read-only mediaSo this parameter does modify the location where the .zip compressed file is created.
But there is a new issue. For some files I am getting a NPE in the console and the applet hangs. Exception in thread "Thread-36" java.lang.StringIndexOutOfBoundsException: String index out of range: -9 at java.lang.String.substring(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.C(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.E(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.D(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.I(Unknown Source) at jfileupload.transfer.client.http.HTTPUploadTransfer.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Not sure what the pattern is. Maybe files that are in the root folder are ok. I also noticed that the file name coming to the server now has the temp folder name in it. For example, C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\excel_save.txt.zip. Can we avoid that? Amrit Re: Exception uploading from read-only mediaAre you using the overall progress bar ?
Re: Exception uploading from read-only mediaWell the only progress bar related parameter I see that we are using is "resetprogressbar". Which is set to true.
Is that what you meant? Re: Exception uploading from read-only mediaNo, JFileUpload can provide two progress bars. One for individual upload (each file one by one) and another for all files (it's the overall progressbar). Overall progress bar is setup in i18n.properties.
Also, you could post here you JavaScript with applet parameters declaration ? Re: Exception uploading from read-only mediaHere is the applet tag:
<APPLET CODE="jfileupload.upload.client.MApplet.class" JAVA_CODEBASE="./" ARCHIVE="/jfileupload/lib/jfileupload.jar,/jfileupload/lib/httpimpl.jar,/jfileupload/lib/chttpclient.jar,/jfileupload/lib/clogging .jar,/jfileupload/lib/batchui.jar,/jfileupload/lib/weakssl.jar" WIDTH="430" HEIGHT="300" NAME="fileupload"><PARAM NAME=CODE VALUE="jfileupload.upload.client.MApplet.class"> <PARAM NAME=CODEBASE VALUE="./"> <PARAM NAME=CACHE_ARCHIVE VALUE="/jfileupload/lib/jfileupload.jar,/jfileupload/lib/httpimpl.jar,/jfileupload/lib/chttpclient.jar,/jfileupload/lib/clogging.jar,/jfileupload/lib/batchui.jar,/jfileupload/lib/weakssl.jar"> <PARAM NAME="CACHE_VERSION" VALUE="_@jappletVersion_@,_@jappletVersion_@,_@jappletVersion_@,_@jappletVersion_@,_@jappletVersion_@,_@jappletVersion_@"> <PARAM NAME=NAME VALUE="fileupload"> <PARAM NAME="type" VALUE="application/x-java-applet;version=1.4"> <PARAM NAME="scriptable" VALUE="true"> <PARAM NAME="url" VALUE="' + _postUrlProtocol + '://' + _postUrl + '/multi-file-upload"> <PARAM NAME="paramfile" VALUE="uploadfile"> <PARAM NAME="param1" VALUE="todo"> <PARAM NAME="value1" VALUE="upload"> <PARAM NAME="param2" VALUE="relativefilename"> <PARAM NAME="value2" VALUE="true"> <PARAM NAME="param3" VALUE="cookiename"> <PARAM NAME="value3" VALUE="JSESSIONID"> <PARAM NAME="param4" VALUE="cookievalue"> <PARAM NAME="value4" VALUE="' + getCookie('JSESSIONID') + '"> <PARAM NAME="param5" VALUE="egnyte.multiFile.targetFolder"> <PARAM NAME="value5" VALUE="' + _targetFolder + '"> <PARAM NAME="param6" VALUE="selectedfullfilename"> <PARAM NAME="value6" VALUE="true"> <PARAM NAME="param7" VALUE="weakssl"> <PARAM NAME="value7" VALUE="true"> <PARAM NAME="param8" VALUE="notifyrelativefilename"> <PARAM NAME="value8" VALUE="true"> <PARAM NAME="forward" VALUE="/jfileupload/multi_file_upload_commit.jsp?egnyte.multiFile.targetFolder=' + encodeURIComponent(_targetFolder) + '"> <PARAM NAME="folderdepth" VALUE="-1"> <PARAM NAME="resume" VALUE="crc"> <PARAM NAME="chunksize" VALUE="2097152"> <PARAM NAME="retry" VALUE="3"> <PARAM NAME="ziponfly" VALUE="zip"> <PARAM NAME="zipignorelist" VALUE="*.zip,*.gz,*.Z,*.avi,*.wmv,*.mpg,*.mpeg,*.wav,*.au,*.bmp,*.jpg,*.jpeg,*.gif,*.mp3,*.jar,*.exe,*.msi"> <PARAM NAME="transferuiresources" VALUE="/jfileupload/i18n_pane"> <PARAM NAME="resetprogressbar" VALUE="true"> <PARAM NAME="mode" VALUE="http"> <PARAM NAME="regfile" VALUE="jfileupload/license.oxw"> <PARAM NAME="encoding" VALUE="UTF-8"> <PARAM NAME="transferui" VALUE="jfileupload.transfer.client.edesign.BatchTransferUI"> <PARAM NAME="transferuiparam1" VALUE="regfile"> <PARAM NAME="transferuivalue1" VALUE="/jfileupload/license.oxw"> <PARAM NAME="tmpfolder" VALUE="javatmpdir"> <PARAM NAME="resources" VALUE="/jfileupload/i18n_bar"> </OBJECT> </NOEMBED></EMBED> </APPLET> Here is the fragment from i18n_bar.properties for the progress bar. # Progress bar panel progress.button.cancel=Cancel #progress.button.cancel.color.background=EEEEEE #progress.button.cancel.color.foreground=000000 #progress.button.cancel.disabled.color=000099 #progress.button.cancel.font.size.factor=2 #progress.button.cancel.font.style=bold progress.button.select=Select file(s) #progress.button.select.color.background=EEEEFF #progress.button.select.color.foreground=000033 #progress.button.select.disabled.color=000099 #progress.button.select.font.size.factor=2 #progress.button.select.font.style=bold progress.button.spacing.x=5 progress.button.spacing.y=2 progress.button.spacing.color=FFFFFF #progress.bar.color.background=DDDDFF #progress.bar.color.foreground=5577FF #progress.bar.color.selection.foreground=0000FF #progress.bar.color.selection.background=0088AA #progress.bar.font.size.factor=2 #progress.bar.font.style=bold #progress.bar.upload.starting.label=Upload starting ... progress.bar.upload.label=Uploading {0}% ({1}) [{2} files left] progress.bar.upload.completing.label=Completing upload ... #progress.bar.upload.completing.color=55AAFF progress.bar.upload.completed.label=Uploaded progress.bar.upload.done.label=Upload completed ({0} files) progress.bar.upload.failed.label=Upload failed : {0} progress.bar.upload.cancelled.label=Upload cancelled progress.bar.upload.checksum.started.label=Computing {0} checksum ... progress.bar.upload.checksum.completed.label=Checksum computed progress.bar.upload.compress.started=Compressing : {0} ... progress.bar.upload.compress.completed=Compression completed progress.bar.upload.compress.failed=Compression failed : {0} progress.bar.upload.filter.started=Filtering to {0} ... progress.bar.upload.filter.completed=Filtering completed progress.bar.upload.filter.failed=Filtering failed {0} #progress.bar.upload.option=chunkratio Re: Exception uploading from read-only mediaOk, I will try to reproduce the problem. Another question: Does it occur when you try to upload a file which is not on a read-only device ?
