PHP Example - Generates JavaScript for Plugin
willkostelecky
Post by willkostelecky »
I wanted my PHP to be pretty and I wanted to dynamically modify parameters for the uploader. This PHP class was the result. It is pretty crude but it does what I want. Adding validation for the parameter names would be a nice add-on.
https://docs.google.com/leaf?id=0BxF8Io ... y=CPWIgbUC
AND...you only have to specify parameters once since the code for the different browsers is generated for you.
Re: PHP Example - Generates JavaScript for Plugin
Hey thanks !
