Chunked files are listed as WAITING and never COMPLETED.Chunked files are listed as WAITING and never COMPLETED.We are using the javascript commands document.fileupload.getState and document.fileupload.getFilenames() to check the status of our large file uploads. The file chunks are each marked as COMPLETED when the upload is finished, but the filename itself (the one without the .# at the end of the name) is always marked as WAITING and never changes status to COMPLETED.
Re: Chunked files are listed as WAITING and never COMPLETED.What about installing JSAPI to get notifications on file upload status?
http://www.jfileupload.com/products/tools/index.html Re: Chunked files are listed as WAITING and never COMPLETED.Thanks. I tried it quickly with our current setup but got the error
java.lang.NoClassDefFoundError: jfileupload/transfer/client/core/N Do you have a jsapi.jar for the premium build? Re: Chunked files are listed as WAITING and never COMPLETED.Thanks support for the jar file.
Looks like JSTransferDone is going to do exactly what I need. |
