Hi.
I'm having some issues with uploading files, as they are not located in the folder I've specified in the process.jsp
It seems the files aren't uploaded at all, though the applet is stating so - see attached picture.
What can it be?
Missing "uploaded" files
Re: Missing "uploaded" filesWhat folder did you setup in process.jsp? Is it an absolute path to a server-side folder? Do you have read/write permissions on it?
Re: Missing "uploaded" filesI have created to folders, CHMOD = 777
Re: Missing "uploaded" filesThat's the problem it must be a folder not an URL. For instance:
String directory = "/home/user/user1/upload/upload"; String tmpdirectory = "/home/user/user1/upload/upload/temp"; Does it help?
Re: Missing "uploaded" filesI have now tried, but it still doesn't work. I looks like I can write anything I want in the path, and it still will say "Upload completed".
Re: Missing "uploaded" filesAre you sure TOMCAT process is allowed to write in these folders?
