Hi list,
I use JBatchUpload with FTP and have..
document.writeln('<PARAM NAME="param4" VALUE="account">');
document.writeln('<PARAM NAME="value4" VALUE="aDirectory">');
Unfortunately if the directory does not exist, JBatchUpload says:
Upload Failed: Cannot change directory
Is there a way to create directories as needed?
Marcus
ftp, create directory if not existsRe: ftp, create directory if not existsSure, add the following parameter:
<PARAM NAME="param5" VALUE="accountcreation"> <PARAM NAME="value5" VALUE="true"> Does it help? Re: ftp, create directory if not existsNot being english native speaker my vocabulary fails to correctly express the massive success of these flags so I'll settle with "Super!".
Thanks! Marcus |
