I'm using proFTPD to uploadvideo and audio files with your applet Jfileupload. File sizes are anywhere from 50 to 500 megs. I'm having constant issues with the upload finishing and then it auto restarts, erased the completed file to nothing and starts the transfer again... and sometimes upload stop at 100% and not execute foward action. BUT it works always from France FAI, but users in Canada using FAI "videotron" it not work. Did you have any idea ?
Here log applet when it does not work with the canada FAI called "videotron" :
< 220 ProFTPD 1.3.1 Server (Debian) [91.121.82.214]
> USER ministry
< 331 Password required for ministry
> PASS *****
< 230 User ministry logged in
> CWD /VIDEO/z_tmp_1_ftp/
< 250 CWD command successful
Envoi en cours : spotfem10mp4_512K5.flv
(4 455 113 bytes)
Envoi de votre fichier en cours ...> TYPE I
< 200 Type set to I
> SYST
< 215 UNIX Type: L8
> PASV
< 227 Entering Passive Mode (91,121,82,214,254,177).
> LIST -spotfem10mp4_512K5-8630.flv
< 150 Opening ASCII mode data connection for file list
< 450 _512K5-8630.flv: No such file or directory
> PASV
< 227 Entering Passive Mode (91,121,82,214,200,230).
> STOR -spotfem10mp4_512K5-8630.flv
< 150 Opening BINARY mode data connection for -spotfem10mp4_512K5-8630.flv
The line : < 226 Transfer complete never appear
(sorry for my english i'm french)
Is anybody can help me ?
Upload finish and then it auto restartsRe: Upload finish and then it auto restartsAre you using any "retry" parameter in your JavaScript?
Re: Upload finish and then it auto restartsYes,
document.writeln('<PARAM NAME="retrydelay" VALUE="15">'); document.writeln('<PARAM NAME="retry" VALUE="40">'); Re: Upload finish and then it auto restartsI think upload fail that's why it restarts. Just try to remove "retry" parameter to see if i'm correct.
Re: Upload finish and then it auto restartsI change information on my servor (increase timeout) and rety value on client applet jfileupload and now it's running, upload never restart anymore.
document.writeln('<PARAM NAME="retrydelay" VALUE="120">'); document.writeln('<PARAM NAME="retry" VALUE="40">'); but sometimes upload stop à 100% and nothing append, there is no redirection after upload, upload stop at 100%. This problem appear not at all times, only sometimes. Could you help me to fix this bug ? thanks Re: Upload finish and then it auto restartsMake a search on "commandmonitor" in this forum. You might face to command channel timeout issue. If your FTP server supports period NOOP commands while uploading then you could workaround this issue.
