When the applet loads, it generates a "General Exception" error. It occurs in both Mozilla and
IE.
Thanks for the help.
RJ
"General Exception" errorRe: "General Exception" errorI guess you've modified the JavaScript. Did it work before modification ?
You modified i18pane.properties too ? Re: "General Exception" errorI have made a number of changes. I think I did this in the prescribed way to reflect the changes that I want to make to the applet. The General Exception Error started when I activated the "Select Images" button and deactivated the menu. I think I did this in the right way. But, obviously these changes also produced the problem.
I am going to email you separately a list of modifications that I would like to see. I have not heard back from goDaddy. But, apart from that, I would like to wrap up these up and purchase and get ready for production operations. Thanks for the help, RJ Re: "General Exception" errorI think the general comes from File menu removal with "Select image(s)" button. It will fix this issue right now.
