I'm trying out your free version before buying and was wondering if you have a solution for the Internet Explorer bug "Press SPACEBAR or ENTER to activate and use this control".
Thanks for the help!
Press SPACEBAR or ENTER to activate and use this controlRe: Press SPACEBAR or ENTER to activate and use this controlAre you using the sample provided with the HTML and JavaScript separated files ?
Do you have the same issue with the online demo ? http://www.jfileupload.com/products/dem ... _http.html |
