Since release 2.6, we had to remove end-user language auto-detection (based on locale) from the applet to get rid of a security warning displayed for JRE 1.6.0_19+. JFileUpload still supports multiple languages but you have to define which resources file to load in JavaScript now. To do so you have update the JavaScript slightly by adding the following lines at the beginning of the JavaScript:
// Language detection
var _language = (navigator["language"])?navigator["language"]:navigator["userLanguage"];
var _file = "i18n";
if (_language.indexOf("en")>=0) _file = _file + "_en";
else if (_language.indexOf("es")>=0) _file = _file + "_es";
else if (_language.indexOf("de")>=0) _file = _file + "_de";
else if (_language.indexOf("fr")>=0) _file = _file + "_fr";
else if (_language.indexOf("cn")>=0) _file = _file + "_cn";
// _file value can be used for "resources" parameter.
document.write('resources="'+_file+'" ');
document.writeln('<PARAM NAME="resources" VALUE="'+_file+'">');
i18n.properties
i18n_cn.properties
i18n_de.properties
i18n_fr.properties
i18n_es.properties
i18n_en.properties The full JavaScript will look like:
var _file = "i18n";
var _info = navigator.userAgent;
var _ns = false;
var _ns6 = false;
var _ie = (_info.indexOf("MSIE") > 0 && _info.indexOf("Win") > 0 && _info.indexOf("Windows 3.1") < 0);
if (_info.indexOf("Opera") > 0) _ie = false;
var _ns = (navigator.appName.indexOf("Netscape") >= 0 && ((_info.indexOf("Win") > 0 && _info.indexOf("Win16") < 0) || (_info.indexOf("Sun") > 0) || (_info.indexOf("Linux") > 0) || (_info.indexOf("AIX") > 0) || (_info.indexOf("OS/2") > 0) || (_info.indexOf("IRIX") > 0)));
var _ns6 = ((_ns == true) && (_info.indexOf("Mozilla/5") >= 0));
if (_ie == true) {
document.writeln('<OBJECT classid="clsid:8AD9C840-044E-11D1-B3E9-00805F499D93" WIDTH="250" HEIGHT="250" NAME="fileupload" codebase="http://java.sun.com/update/1.4.2/jinstall-1_4-windows-i586.cab#Version=1,4,0,0">');
else if (_ns == true && _ns6 == false) {
// BEGIN: Update parameters below for NETSCAPE 3.x and 4.x support.
document.write('<EMBED ');
document.write('type="application/x-java-applet;version=1.4" ');
document.write('CODE="jfileupload.upload.client.MApplet.class" ');
document.write('JAVA_CODEBASE="./" ');
document.write('ARCHIVE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar" ');
document.write('NAME="fileupload" ');
document.write('WIDTH="250" ');
document.write('HEIGHT="250" ');
document.write('url="http://localhost:8080/upload/process.jsp" ');
document.write('paramfile="uploadfile" ');
document.write('param1="todo" ');
document.write('value1="upload" ');
document.write('mode="http" ');
document.write('scriptable=true ');
document.writeln('pluginspage="http://java.sun.com/products/plugin/index.html#download"><NOEMBED>');
// END
else {
document.writeln('<APPLET CODE="jfileupload.upload.client.MApplet.class" JAVA_CODEBASE="./" ARCHIVE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar" WIDTH="250" HEIGHT="250" NAME="fileupload">');
// BEGIN: Update parameters below for INTERNET EXPLORER, FIREFOX, SAFARI, OPERA, MOZILLA, NETSCAPE 6+ support.
document.writeln('<PARAM NAME=ARCHIVE VALUE="lib/jfileupload.jar,lib/httpimpl.jar,lib/chttpclient.jar,lib/clogging.jar">');
document.writeln('<PARAM NAME="url" VALUE="http://localhost:8080/upload/process.jsp">');
// END
if (_ie == true) {
document.writeln('</OBJECT>');
document.writeln('</NOEMBED></EMBED>');
else {
document.writeln('</APPLET>');
