Since 2.6 you can choose which FTP command is sent to server when using overwrite parameter.
Default is NLST. You can switch to LIST command instead with:
<PARAM NAME="param6" VALUE="listcommand">
<PARAM NAME="value6" VALUE="list">
Overwite and FTP command issuedOverwite and FTP command issuedSince 2.6 you can choose which FTP command is sent to server when using overwrite parameter.
Default is NLST. You can switch to LIST command instead with: <PARAM NAME="param6" VALUE="listcommand"> <PARAM NAME="value6" VALUE="list"> |
Sitemap | Privacy Statement | All company and/or product names are the property of their respective owners.
