Please help:
Exception: java.lang.NoClassDefFoundError: jfileupload/upload/client/MApplet
Ignored exception: java.lang.NoClassDefFoundError: jfileupload/upload/client/MApplet
Firefox 3.6 Java ErrorFirefox 3.6 Java ErrorHi,
Please help: Code: Select all
Re: Firefox 3.6 Java ErrorIt's under firefox 3.6 only ? Another user reported an issue with FF 3.6 with JavaScript calls (regression known on FireFox bug tracking database).
Are you testing online or locally (by opening the applet from c:/) ? Try online. Re: Firefox 3.6 Java ErrorYes, error appears only after updating to Firefox version 3.6.
The website is online. My installation uses JavaScript calls as well. Re: Firefox 3.6 Java ErrorThe other customer reported that some JavaScript functions needed to be called twice to work.
Re: Firefox 3.6 Java ErrorThis is not very helpful. I have no JavaScript functions to call twice, the applet is looking for a file named "jfileupload/upload/client/MApplet.class", which obviously doesn't exist on the server.
Re: Firefox 3.6 Java ErrorIt is the same error message I was receiving here: viewtopic.php?f=2&t=378, only that this time I have no workaround for it. There must be something wrong withing the JSAPI addon as without it seems to work fine.
Re: Firefox 3.6 Java ErrorI've updated the Java installation from "1.6.0_17" to "1.6.0_18" and this somehow fixed the problem.
Re: Firefox 3.6 Java ErrorGreat ! I also have 1.6.0_18.
Sitemap | Privacy Statement | All company and/or product names are the property of their respective owners.
