drag and drop does not work with chrome or internet explorer
chuckmpw
Post by chuckmpw »
this must be a security setting in the browsers but i can't seem to find it.
drag and drop works with firefox but not chrome or internet explorer 11. the only way to load files is through the "file" menu. then you can't load folders.
Re: drag and drop does not work with chrome or internet expl
Which version of Chrome are you using?
