If you experiment issues when loading applet under Java 8 over SSL/TLS, then under Java Control Panel, Security, disable "TLS 1.2", Apply and try again.
See:
https://blogs.oracle.com/java-platform- ... ll_use_tls
If it works then it means your web server does not support TLS1.2
