Can not access to folder after we sort file list
xzgan
Post by xzgan »
Hi all,
I found a serious issue after we click sorting column, all the directories can not be accessed when we double click folder.
You still can find this issue in your official env:
http://www.jfileupload.com/products/dem ... _http.html
steps: Files--> select files--> Details->click Date modified
then double click a folder, the issue will occur.
Re: Can not access to folder after we sort file list
Looks good from here with JRE 1.7.0_67-b01
