Problem with resume
alexto
Problem with resume
Post by alexto »
Failed to configure the resume.
Here is the text of config:
// BEGIN: Update parameters below for NETSCAPE 3.x and 4.x support.^M
document.write('<EMBED ');^M
document.write('type="application/x-java-applet;version=1.6" ');^M
document.write('CODE="jfileupload.upload.client.MApplet.class" ');^M
document.write('JAVA_CODEBASE="./" ');^M
document.write('ARCHIVE="lib/jfile/jfileupload.jar,lib/jfile/httpimpl.jar,lib/jfile/chttpclient.jar,lib/jfile/clogging.jar,lib/jfile/explorerui.jar" ');^M
document.write('NAME="fileupload" ');^M
document.write('WIDTH="99%" ');^M
document.write('HEIGHT="98%" ');^M
document.write('url="http://www.xxx.xx:80/process_debug.php" ');^M
document.write('paramfile="uploadfile" ');^M
document.write('param1="todo" ');^M
document.write('value1="upload" ');^M
document.write('param2="relativefilename" ');^M
document.write('value2="true" ');^M
document.write('param3="emptydirectory" ');^M
document.write('value3="true" ');^M
document.write('folderdepth="-1" ');^M
document.write('sm="enabled" ');^M
document.write('resume="true" ');
document.write('retry="5" ');
document.write('overwrite="true" ');
document.write('overwritewarn="true" ');
document.write('encoding="UTF-8" ');
document.write('transferui="jfileupload.transfer.client.explorer.ExplorerTransferUI" ');^M
document.write('resources="i18n_bar" ');^M
document.write('transferuiresources="i18n_pane" ');^M
document.write('mode="http" ');^M
document.write('scriptable=true ');^M
document.writeln('pluginspage="http://java.sun.com/products/plugin/ind ... "><NOEMBED>');^M
// END
// END
Re: Problem with resume
Is resume enable in PHP script?
