overwrite example using perl CGIoverwrite example using perl CGIIs there any example of using perl with the overwrite parameter?
Re: overwrite example using perl CGINo, CGI sample just implement the basics
Re: overwrite example using perl CGII was wonder if the overwrite even works with perl cgi. That is the reason I asked for an example. When I look at the cgi object when the HEAD request is sent, I do not see the upload file name.
Re: overwrite example using perl CGICan you tell me what the server side script has to return to abort the upload if there is a duplicate file name?
Re: overwrite example using perl CGINevermind, I have resolved this.
