Yes i have used the
<PARAM NAME="encoding" VALUE="UTF8">
In the Control Message the file name is perfect..
But in java console it comes with ??? characters..
I have already gone through
viewtopic.php?f=2&t=173&p=770&hilit=chinese#p770
Here is my console..!
Java Plug-in 1.6.0_33
Using JRE version 1.6.0_33-b03-424-11M3720 Java HotSpot(TM) 64-Bit Server VM
User home directory = /Users/administrator
c: clear console window
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
network: Connecting
http://172.22.130.24:21/ with proxy=DIRECT
[INFO] FTPTransfer - Connected to
ftp://172.22.130.24
[INFO] FTPTransfer - 220 Microsoft FTP Service
[INFO] FTPUploadTransfer - Upload started : /Users/administrator/Downloads/aspnet??aspnet??.wmv
[ERROR] FTPUploadTransfer - jfileupload.transfer.client.core.ClientException: Transfer failed
[INFO] FTPUploadTransfer - Attempt 1/3
[INFO] FTPTransfer - Disconnected from
ftp://172.22.130.24
network: Connecting
ftp://172.22.130.24
[INFO] FTPUploadTransfer - Attempt 2/3
ftp://172.22.130.24
network: Connecting
ftp://172.22.130.24
[INFO] FTPUploadTransfer - Attempt 3/3
ftp://172.22.130.24
network: Connecting
ftp://172.22.130.24
[INFO] FTPUploadTransfer - Upload failed
ftp://172.22.130.24
