Integration into Spring primefaces project
nincsneve
Post by nincsneve »
currently I am trying to integrate JFileupload into a Spring webproject for school, with primefaces. Now it is working, but I have some questions about integration:
- Is it possible to get rootcontext of web application to use it in "applet_http.js" for "url=" ?
I placed process.jsp in the same folderstructure as the applet, but I have to customize the url every time, when I try out different server-deployments
- How can I get parameters, like "filesize", "destination directory", etc. to store these information in database?
I am very happy with the possibilities of this application and will buy I license to remove "unregistered" when the project is finished
Re: Integration into Spring primefaces project
For parameters in database, it's just a matter of dynamic HTML/JavaScript page generation. You can have a applet_http.js.php script will parameters loaded from database.
For context root usage you should use absolute URL in CODEBASE parameter such as:
CODEBASE="http://yourserver.com/contextroot/whatyouwanthere"
