connection reset by peer: socket write error
luctuf2
Post by luctuf2 »
Hi to all!
I've the problem in the subject: i have used jdiskexplorer (licensed) successful in my website. After a change of mantainer i've experienced this error. the ftp transfert doesn't start. i'm unable to create a directory or upload any kind of file.
below the java debug report...please, help me! :oops:
thanks in advance
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws,com.sun.deploy
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws,com.sun.deploy
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition value null
security: property package.definition new value com.sun.javaws
security: property package.definition value com.sun.javaws
security: property package.definition new value com.sun.javaws,com.sun.deploy
security: property package.definition value com.sun.javaws,com.sun.deploy
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.access new value sun.,com.sun.xml.internal.ws.,com.sun.xml.internal.bind.,com.sun.imageio.,com.sun.org.apache.xerces.internal.utils.,com.sun.org.apache.xalan.internal.utils.,com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp
security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
basic: Aggiunto listener avanzamento: sun.plugin.util.ProgressMonitorAdapter@c94b56
basic: Plugin2ClassLoader.addURL parent called for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar
basic: Plugin2ClassLoader.addURL parent called for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar
basic: Plugin2ClassLoader.addURL parent called for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar
basic: Plugin2ClassLoader.addURL parent called for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar
basic: Plugin2ClassLoader.addURL parent called for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar con proxy=DIRECT
network: CleanupThread used 41488 us
network: Connessione a http://www.albumdea.com:80/ con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
basic: Caricamento di Applet Java in corso...
network: CleanupThread used 1 us
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar
	Content-Length: 113.038
	Content-Encoding: null
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\46\5e07e16e-711555b3-temp
security: La verifica di revoca della lista di esclusione è abilitata
security: Il controllo della lista librerie sicure è abilitato
security: Accesso alle chiavi e al certificato nel profilo utente di Mozilla: null
security: Caricamento certificati di distribuzione da C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
security: Certificati di distribuzione caricati da C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
security: Caricamento certificati dallarea di memorizzazione dei certificati della sessione di distribuzione
security: Certificati caricati dallarea di memorizzazione dei certificati della sessione di distribuzione
security: Convalidare la catena certificati utilizzando lAPI CertPath
security: Caricamento certificati della CA radice da C:\Program Files (x86)\Java\jre7\lib\security\cacerts
security: Certificati della CA radice caricati da C:\Program Files (x86)\Java\jre7\lib\security\cacerts
security: Ottenere la raccolta certificati nellarea di memorizzazione dei certificati della CA radice
security: Il certificato non è scaduto, non è necessario controllare le informazioni di data e ora
security: File lista giurisdizioni trovato
security: Avvia controllo dellestensione sicura per il certificato
security: Avvia confronto tra lista delle giurisdizioni e il certificato
security: Supporto CRL disabilitato
security: Il supporto OCSP è disabilitato
security: La convalida entità di fine OCSP è disabilitata
security: Controllo della presenza del certificato nellarea di memorizzazione dei certificati respinti della distribuzione
security: Controllo del certificato nellarea di memorizzazione dei certificati di distribuzione permanenti
basic: updateValidationResultsForApplet update
cache: Mark prevalidated: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/jfileupload.jar true tm=1337071541439 cert=1361923199000
basic: Plugin2ClassLoader.getPermissions CeilingPolicy allPerms
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar
	Content-Length: 25.495
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\42\61a6566a-5dfd115a-temp
cache: Mark prevalidated: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/ftpimpl.jar true tm=1337071542032 cert=1361923199000
network: CleanupThread used 0 us
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar
	Content-Length: 194.736
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\50\a31e272-4f0be5c3-temp
network: CleanupThread used 2 us
cache: Mark prevalidated: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar true tm=1337071544263 cert=1361923199000
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar
	Content-Length: 45.775
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\21\4c6cba95-634fb099-temp
cache: Mark prevalidated: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/clogging.jar true tm=1337071547866 cert=1361923199000
[INFO] MApplet - JFileUpload 2.9 Build FINAL.001
basic: Applet caricata.
basic: Applet resized and added to parent container
basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 113603 us, pluginInit dt 7915208 us, TotalTime: 8028811 us
[INFO] MApplet - CustomSM enabled
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_bar.properties, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_bar.properties con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_bar.properties con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_bar.properties
	Content-Length: 7.639
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_bar.properties scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\2adf5911-6f2bd8ac-temp
[INFO] D - Ftp simultaneous connections = 1
[INFO] E - Control encoding: ISO-8859-1
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar
	Content-Length: 77.914
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\31\2190b09f-6b6e784f-temp
cache: Mark prevalidated: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar true tm=1337071550939 cert=1361923199000
[INFO] Conf - TransferUI instantiated : jfileupload.transfer.client.explorer.ExplorerTransferUI
[INFO] ExplorerTransferUI - JDiskExplorer 2.9 FINAL.001
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_pane.properties, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_pane.properties con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_pane.properties con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_pane.properties
	Content-Length: 3.165
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/i18n_pane.properties scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\1\57cac41-2df8fca5-temp
[INFO] A - Loading regFile : modules/mod_ftpupload/applet/explorer.oxw
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/explorer.oxw, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/explorer.oxw con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/explorer.oxw con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/explorer.oxw
	Content-Length: 1.094
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/explorer.oxw scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\1\6cd2c901-3a42b938-temp
[INFO] A - Registered to :www.albumdea.com
[INFO] A - Loading regFile : modules/mod_ftpupload/applet/license.oxw
network: Voce cache non trovata [URL: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/license.oxw, versione: null]
network: Connessione a http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/license.oxw con proxy=DIRECT
network: Connessione http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/license.oxw con cookie "1b576218202213eaaf6138fc2c045fb8=t5a98t985o93qjoiivpitujlt7"
network: Scaricamento risorsa: http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/license.oxw
network: URL http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/license.oxw scritto su file C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\15\275434cf-6d76b60c-temp
basic: Applet initialized
basic: Starting applet
basic: completed perf rollup
basic: Applet made visible
basic: Applet started
basic: Told clients applet is started
Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException
	at jfileupload.transfer.client.explorer.C.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.AbstractButton.doClick(Unknown Source)
	at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
	at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$000(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue$4.run(Unknown Source)
	at java.awt.EventQueue.dispatchEvent(Unknown Source)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
	at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
	at java.awt.EventDispatchThread.run(Unknown Source)
cache:  Read manifest for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/explorerui.jar: read=107 full=2511
network: Connessione a http://195.128.234.23:21/ con proxy=DIRECT
cache:  Read manifest for http://www.albumdea.com/userarea/modules/mod_ftpupload/applet/lib/cnet.jar: read=267 full=5274
[INFO] E - Connected to ftp://195.128.234.23
[INFO] E - 220 ProFTPD 1.3.3a Server (Debian) [::ffff:195.128.234.23]
[INFO] E - PASV enabled
[INFO] FTPUploadTransfer - Upload started : C:\Users\Administrator\Desktop\immagini\Desert.jpg
[ERROR] FTPUploadTransfer - java.net.SocketException: Connection reset
[ERROR] E - NOOP failed <java.net.SocketException: Connection reset by peer: socket write error>java.net.SocketException: Connection reset by peer: socket write error
	at java.net.SocketOutputStream.socketWrite0(Native Method)
	at java.net.SocketOutputStream.socketWrite(Unknown Source)
	at java.net.SocketOutputStream.write(Unknown Source)
	at sun.nio.cs.StreamEncoder.writeBytes(Unknown Source)
	at sun.nio.cs.StreamEncoder.implFlushBuffer(Unknown Source)
	at sun.nio.cs.StreamEncoder.implFlush(Unknown Source)
	at sun.nio.cs.StreamEncoder.flush(Unknown Source)
	at java.io.OutputStreamWriter.flush(Unknown Source)
	at java.io.BufferedWriter.flush(Unknown Source)
	at org.apache.commons.net.ftp.FTP.sendCommand(Unknown Source)
	at org.apache.commons.net.ftp.FTP.noop(Unknown Source)
	at jfileupload.transfer.client.ftp.E.G(Unknown Source)
	at jfileupload.transfer.client.explorer.ftp.FTPRemoteTFileSystem.E(Unknown Source)
	at jfileupload.transfer.client.explorer.ftp.FTPRemoteTFileSystem.B(Unknown Source)
	at jfileupload.transfer.client.explorer.C.C(Unknown Source)
	at jfileupload.transfer.client.explorer.C.A(Unknown Source)
	at jfileupload.transfer.client.explorer.C.transferFailed(Unknown Source)
	at jfileupload.transfer.client.ftp.FTPUploadTransfer.run(Unknown Source)
[ERROR] FTPRemoteTFileSystem - java.net.SocketException: Connection reset by peer: socket write error
[INFO] FTPUploadTransfer - Upload failed
Re: connection reset by peer: socket write error
Are you using FTP or FTPS?
