Proxy with authentication
import
Post by import »
It seems that the authentication of a proxy is not taken into account by the applet (?)
- Can you confirm ?
- Is it on the dev roadmap ?
thx !
INFO: Registered to :***
25 sept. 2007 11:56:02 jfileupload.transfer.client.http.HTTPUploadTransfer C
INFO: Upload (POST) started : E:\***.pdf
INFO: Upload Status code = 407
INFO: Upload failed
import
Re: Proxy with authentication
Post by import »
2 solutions for proxy support are already available in official release:
1 - Add the following parameter:
<PARAM NAME="authentication" VALUE="auto">
2 - Try to install JSEHTTP add-on:
Try solution 1 first because solution 2 has some limitations about upload size.
import
Post by import »
Sounds easy ! I'll try and keep you posted ;
Thx
