JFileUpload with overwite parameter and indexrename
import
Post by import »
I am using the LargeUpload.jsp example file for Uploadbean.
JFileUpload has the following set in the right place
<PARAM NAME = "overwrite" VALUE = "indexrename">
The applet works but it alwas overwites the previous file, the
documentation says that using this option will rename duplicate
uploads such as file_1.zip...
The FAQ says LargeUpload.jsp provided this feature.
Something is wrong since it does NOT work.
import
Re: JFileUpload with overwite parameter and indexrename
Post by import »
Is there any URL we could check to see what's wrong ?
import
Post by import »
My bad...
It works! When I was trying to make an example to show how it does not work, I got it to work.
indexrename DOES work exactly as it should.
import
Post by import »
great!
