How do direct the uploaded files to a specific temp folder?How do direct the uploaded files to a specific temp folder?Q. How do I instruct JFileUpload where to place the uploaded files?
Re: How do direct the uploaded files to a specific temp folder?That depends on the server side script that you are using to process the upload.
Re: How do direct the uploaded files to a specific temp folder?Using ASP.NET .aspx page...
Re: How do direct the uploaded files to a specific temp folder?Sorry, not in my area of expertise, I'm a PHP developer Good luck with that!
Re: How do direct the uploaded files to a specific temp folder?You have a ASP.NET sample where you can setup server-side folder for uploaded files at:
http://www.jfileupload.com/products/tools/index.html |
