Is there any way where the Jfileupload applet chunks only if the file size exceeds some limit though we include chunk size parameter in aspx?I need only the files of size>1.5GB to be chunked.
I also need the server side code for the Resume feature combined with chunking.Currently I have implemented code for Resume feature with out chunking.
How does chunking and Resumable upload worktogether ?
Re: How does chunking and Resumable upload worktogether ?You need only the files of size > 1.5GB to be chunked and the chunksize will be < to 1.5GB (for instance 500 MB), correct ?
Re: How does chunking and Resumable upload worktogether ?Yes, I need the chunking to work only for the files of size>1.5GB though the chunksize we pass to the applet is (for example) 512MB.
Resume feature is not working with chunking.Any help in this please? Re: How does chunking and Resumable upload worktogether ?To make resume works with chunking:
<PARAM NAME="overwrite" VALUE="false"> <PARAM NAME="resume" VALUE="true"> <PARAM NAME="chunksize" VALUE="somevalue"> If upload stops in the middle of chunk 5 then on next upload attempt, the applet will skip chunk 1 to 4 because of 'overwrite=false' and will resume chunk 5 and continue upload until the end of chunks. However, do not use: <PARAM NAME="chunkmode" VALUE="onfly"> and avoid "template" parameter. The drawback is the chunks (temporary) are created locally before upload. Does it help ? |
