I need to rename the file downloaded, to give the target file a specific name.
This is because the source filename is managed by a database and it is not the filename that the user expect...
It is only for a one file download scenario.
Example :
The applet download "element_2145", but display and save "YourFile.zip" for the user concern.
I didn't see any parameter nor example to do that in the documentation.
Is it possible ?
Thanks for any help.
how to rename the file downloadedRe: how to rename the file downloadedNo, you cannot rename. It uses the name in parameters "item1...". However, it's a feature we could add if you're willing to pay for it. If so then please contact support(at)jfileupload(dot)com
